#1 Posted : Sunday, 11 December 2005 8:23:32 PM(UTC)
Hi,
I have been researching new rims to fit my HZ wagon for a while now. I have found some 17" ROH RT's that have the correct PCD (5x120.65mm), however I am unsure of their offset and if they will be to big to fit. They are 17"x9" and 17"x8" and I was told that they have '4 INCH BACK SPACE'. Can someone tell me if that is the same as the offset?? I am guessing that the distance from the outer rim to the plate where the wheel nuts are secured is 4".
Anyways if anyone can help or has experience with RT's I would appreciate hearing your tale.
Cher.
KiwiHQ Offline
#2 Posted : Monday, 12 December 2005 2:17:25 AM(UTC)
KiwiHQ
http://www.rsracing.com/tech-wheel.html shows what you need to know. Also i would check with a tyre shop who should be able to tell you the backspacing and offset numbers you need.
Rock n Roll
Edited by user Monday, 12 December 2005 2:22:16 AM(UTC)  | Reason: Not specified
Rock n Roll
#3 Posted : Monday, 12 December 2005 6:35:44 PM(UTC)
Check the law in your state , in SA you can only go 2 inches bigger in dia from factory , a mate had 18`s on a VS calias and was defected as factory was 15inch = 3inches , HJ was 14 inch so 16 might be the biggest . A lot of people get away with it but if
This page was generated in 0.125 seconds.
