Hi guys and gals just wondering if anyone has fitted the VK Commodore Fuel injection to a HZ Kingswood and if so what do I need to complete this upgrade and how would I go about wiring it into my HZ's exsitsting wiring. Any help or advise on this would be very much appreciated.
there is a great step by step c/o detailed here www.oldholdens.com
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
It's an easy conversion. However I would recommend doing a VN 5.0L conversion instead. Same amount of work, more power and similar fuel economy. You can buy a smashed VN 5.0L at auction for around $1500 nowadays, so the actual cost is probably $1000 more |
Thanks 70ute the link you posted was much informative and will really help make life easier. Thanks also to you Byron Rich but I think I will stick to the 6 cyl option as there is less work and less driveline to change but man it would be nice to drop Edited by user Tuesday, 13 December 2005 2:22:06 AM(UTC)
| Reason: Not specified
quote: Originally posted by HZWGN
...but man it would be nice to drop a 5ltr V8 under the bonnet but she who must be obeyed is
If you must have a 6 cylinder (or lose peace), consider a VNS2/VP/VR V6 also. Whole cars with good motors are selling for $400! It is actually dearer for the V6 'kit' than it is to fit the 5.0L, but there is exactly the same amount of fuel system stuff ar |
I did look into the V6 conversion option but could not find any information on how or what was needed for the conversion. The other thing is I really dont like the idea of having to change diffs if that is part of the mod and I could not find out wher Edited by user Tuesday, 13 December 2005 5:06:28 PM(UTC)
But how nice does a detailed 6 look :) I love them  |
Pete,
ThOse PHOTOS SHOOT Byrons Reasoning DOWN IN FLAMES !!!
666 |
666 |
666, you are truly evil...
Pete,
As much as I hate to accent the V6 v Tru 6 (Power v Nostalga) Option,
Do u run a Haltac or Similar as opposed 2 the Sh*tty Bosch ignition ?
666 |
666 |
quote: Originally posted by 666
Pete,
666
The EFI conversion is not that hard. Use a black head either carby or injected doesn't matter although the carby head you will have to block the air pump ports. If you put the injection stuff on your old red block (recommended because then you only need
Hey guys thanks for all the input have just purchased a grotty but low K 86 VK with unleaded motor and of course the all important injection system and have already started pulling down the old red for the new mods. Everything going to plan it should be u
One thing I have seen done when putting an EFI conversion (202, V6 or 5L) into a HQ-WB is to move the battery to the other side so that you can then fit the STD commodore airbox, and as John has said plumb a duct in to get cold air from in front of the ra |
With the V6 and V8, I'd agree with Byron...Move the battery to the driver's side. However, the 202 injection points the intake to the driver's side, so I'd recommend leaving the battery on the passenger's side and running the intake for the airbox through
The motor is 186 block with VK unleaded head and stock injection and computer. The cam runs it up to real high revs and it appears to cope well with the weight of the Limo.
Coupled to a Trimatic and 3.08 diff it is a cruising machine, that probably get
www.v6conversions.com.auall the info and bits you will need. i agree, if a 6cyl is the only option, go a VN series II- VR series I (non ecotec) conversion. buckets more torque, economy and reliability (the VK EFI computers aren't known for there r
