edmundo Offline
#1 Posted : Monday, 19 December 2005 9:30:32 PM(UTC)
edmundo
does anyone know a price on a reco turbo 350, for a 308 hq. Mine is R.S.
i am in melb
#2 Posted : Monday, 19 December 2005 10:50:42 PM(UTC)
It will cost you between $400 and $900 to rebuild yours, condition dependant. Try buying a complete late VB or VC 308 Commodore. These had TH350's in them. So did early WB Statesman.
#3 Posted : Monday, 19 December 2005 10:56:41 PM(UTC)
Hey Bryon, Is the TH350 suited to the 253 to if not what would be a good automatic transmission for my 253.
Elvis.
EAP
#4 Posted : Tuesday, 20 December 2005 12:06:11 AM(UTC)
A good auto for a 253 is a Trimatic (technical term TH175). They bolt straight up, don't use a lot of HP to run and can be made VERY tough for not a lot of money.
Cheers...Dave
#5 Posted : Tuesday, 20 December 2005 4:04:45 AM(UTC)
I second that, especially the later boxes out of the VL 5.0L. To fit a TH350 to your 253 you need to get the block redrilled to suit the gearbox, noting that pre late 1974 blocks can't be redrilled. Redrilling will cost about $150. Other options are a VN
#6 Posted : Tuesday, 20 December 2005 9:01:13 AM(UTC)
The trimatic automatic trans is a great light weight auto, and can be made very strong.This auto is your best bet. Second hand V8 trimatics are usually no good and worn out. They have big problems with pumps and reverse clutches. If u have one rebuilt and
