#1 Posted : Thursday, 20 May 2004 6:14:37 AM(UTC)
I broke my clutch rod last night on the Q on an off ramp from the M5. Great fun no clutch at the lights. Anyway bodgie it up enough to get to a servo then did a good patch up job to get me home.
I replaced it this morning with a nos HOLDEN part from teh local Scott AutoOne. The mechanic who fitted suggested it track down a "Rat trap" wierd name. Which is the rest of the clutch assembly linkage and bring it in to him and they will rebuild it and rebush it, then replace my existing one. 30 years of wear and tear mean it is not long for this life. If anyone has a clutch assembly linkage for a manual V8 HQ clutch lying around could they email me. I'd rather clean up someones shed for a few bucks before I head to the wreckers.
<p>
thanks Scott
<p>
[email protected]
#2 Posted : Thursday, 20 May 2004 8:10:07 AM(UTC)
If I remember correctly (this is brain data from the early 80's) the 6cyl and V8 setups are the same except for the little bracket which bolts to the bellhousing, which doesn't wear. What I'm trying to say is you can use a 6cyl one, with your V8 bracket.
#3 Posted : Thursday, 20 May 2004 9:19:16 AM(UTC)
Got one here you can have pay the postage. Unfortunately I oxied it off at the long rod thing not sure how much is left, still attached to the box. Will have a look tomorrow if that helps.
#4 Posted : Friday, 21 May 2004 4:28:22 AM(UTC)
If you dont take johns butchered one, I Have one aswell. Have the whole bellhousing, fork, bearing and cable aswell. email kempster at dart.net.au (remove spaces and at = @)
#5 Posted : Saturday, 22 May 2004 2:08:32 AM(UTC)
Thanks guys. I thought the 6 would be similar however wasn't sure. I'll see how I get on,
Scott
#6 Posted : Saturday, 22 May 2004 6:42:45 AM(UTC)
We have several do you want sterring wheel to fit
Yours
Jimbo
0267644333
This page was generated in 0.102 seconds.
