#1 Posted : Monday, 17 April 2006 2:21:45 AM(UTC)
Ok so my mind is made up on what i'm doing to the motor and trans, they're already underway.
Now i've decided to change my diff, i want one with an lsd center and close to standard gear ratio for a six, any body suggest what diff would be good? drum or disc's doesn't bother me.
Going by the results of kieths build up i'd predict about 80-100kw at the bags.
The trans is a trimatic with a stage 2 shift kit.
Thanks Steve
Football, Meat pies, Kangaroo's and Holden cars
#2 Posted : Monday, 17 April 2006 8:25:58 AM(UTC)
need more info mate
#3 Posted : Monday, 17 April 2006 9:40:46 PM(UTC)
More info on what sorry?
The motor is a red 202, its going into my HJ sedan.
#4 Posted : Wednesday, 19 April 2006 8:43:43 AM(UTC)
Anyone there with any opinion? diffs are one thing i know nothing about.
#5 Posted : Wednesday, 19 April 2006 9:55:55 AM(UTC)
OK, I'll bite...
So long as you don't do roll-backs and 4 grands clutch drops, why change your diff? even if it is a banjo, if you don't abuse it it will last for years.
If you do abuse it, either a salisbury out of an HQ - early HX (not sure if the
#6 Posted : Thursday, 20 April 2006 3:02:38 AM(UTC)
Thanks Dave, i think i might look in to the salisbury, from a hq.
#7 Posted : Thursday, 20 April 2006 6:41:23 AM(UTC)
4 grand clutch dumps are just to tempting!
Nothing beats cubic inches !!!
HK1837 Online
#8 Posted : Thursday, 20 April 2006 5:47:25 PM(UTC)
Pretty difficult to do with a trimatic though!
#9 Posted : Friday, 21 April 2006 11:32:10 AM(UTC)
You're right Byron, forgot it was a Tri by the time I replied...but you can do 4 grand neutral to drive dump (not recommended though)... :-)
Cheers...Dave
#10 Posted : Thursday, 27 April 2006 12:43:28 AM(UTC)
if your looking for the dunnydore diffs why not try the utes im sure they had solid axel in the vg n so on (any ways i was told by local diff shop as i brake diffs abit with this combo 350 chev turbo 400 box and hj ute... the holden later model commodo
Guest (7)
