#1 Posted : Tuesday, 4 July 2006 10:38:12 PM(UTC)
Hi all , can someone tell the difference between these two engines , are the 400's a good engine and do they have good power like the 351's. Are the 400's easy to rebuild and can i put 4v closed hds on them and will they bolt straight in a falcon coupe without changes.
thanks
XB351 Offline
#2 Posted : Wednesday, 5 July 2006 2:02:07 AM(UTC)
XB351
302-351C = 9.2" deck height
400 = 9.5" deck height
Only compatible parts are water pump and heads practically. 400's a low comp truck motor. Performance parts for the 400 are being brought into production. A 400ci engine wouldn't be a slouch by anyone
Paul351xb Offline
#3 Posted : Wednesday, 5 July 2006 8:49:36 AM(UTC)
Paul351xb
A mate of mine is dropping a 400 into his XA coupe. I don't remember the exact specs but it is a VERY worked motor. Consider the 400 a clevo on steroids. I'll send him a link to this discussion as I'm sure he'd like to put his 2 cents in.
Paul.
Edited by user Wednesday, 5 July 2006 8:57:53 AM(UTC)  | Reason: Not specified
#4 Posted : Wednesday, 5 July 2006 10:36:36 AM(UTC)
Hey Steve,
I'm Paul's friend that's dropping a 400 into my XA hardtop. There are many good 302C/351C/351M/400 forums (I like the Ford 335 Forum) on the web if you want to find out more about the motors (there is also a lot of misinformation). But, in
