what would i have to change to replace my 186 with a 308 with turbo 400 trans in ht panelvan van is currently manual do i only have to change engine mounts and gearbox crossmember radiator any info would help
Ditch the TH400 for a TH350 and it's a bolt in. What you will need apart from obvious like fuel line, exhaust etc is:
HT/G engine mount adapters and engine mounts (HQ-WB may fit but not 100% sure). HT/G 253/308 accelerator linkage across firewall and |
thanks for your time and effort will start looking for th350
i have heard that i can get an adapter plates to change non turbo 308 engine to take turbo 350 trans are they ok and is that all is needed
Try Greg. Or look in pre mid 1982 WB Statesmans and Commodores except VB's which can also be TH400. |
