I have a 1991 VQ statesman and I need some advice on the central locking/alarm module.
When I purchased the car I did not get any keyless entry remotes, I was hoping to change the module as I got one with a remote for free. I believe its a series 1.
I was wondering if anyone out there could help me with a diagram or anything to show me where it is located and any instructions or advice to get the thing out.
Please anyone with some advice PLEASE write back.
Thanks (xoxoxoxoxoxoxoxo)
The module is located under the crashpad, above the glovebox.
I'm not sure how easy it is to get to - you may be able to get in there by removing the glovebox, but if that doesn't work you'll need to remove the whole dash.
Worst case scenario, if yo |
I told him that you'd know Mick...thanks for not letting me down :-))
Cheers...Dave
No worries Dave!
If you need more detailed instructions on dash removal, let me know, as it's not easy for a first-timer.
A lot of people aim to achieve nothing in l |
I have had the glovebox out and there is a black plastic panel behind it any ideas how to get that out? Any advice you can give me about getting the dash out and back in is great.
1. Take out the centre console and move it back an inch or so. 2. Undo the 3 screws along the bottom of the radio surround, and pop it out. 3. Lower the fuse cover & remove it (pin like the glovebox). 4. Undo the screw holding the climate screen & remo |
Thanks I'll try and see what happens.
