Hey guys, Have been having some hassles with my rocker nuts coming loose. Have solved this now by fitting new nuts, The question is, my book tells me to adjust the rockers to 1/2 to 1 turn past the zero clatter point, but a few guys in the know tell me a 1/4 turn is the best....Which is correct? I currently have them set to 1/2 turn, but still have a misfire, would backing them off to 1/4 turn help?
Hi Les,
I always went ½ a turn past zerolash on my Torries and they all rev'd to 6,300...I think you have another problem (leaking/bent valve or an ignition problem) if you have a miss in your motor.
Cheers...Dave
Dave, Could too wider point gap cause the same problem?? as i think that my point gap is too wide.I would fit my electronic dizzy but the vacuum advance is not working on it,and i dont know how to remove the plate to get the vacuum advance out, do you hav
Hi Les.
You don't need to remove the reluctor plate in an HEI dissy to replace the vacuum advance diaphragm unit.
Just undo the 2 screws holding the diapragm, pull it slightly & 'wriggle' the arm a little & it will come out. There is no circlip or a |
Cheers, I'm going to have a go at it now.I'll get back to ya if I have any drama's.
Ok I cant seem to get the vacuum advance unit out, I definatley looks like i have to remove the plate with the 6 magnet things on it
Hi Les.
Trust me Les, it will come out.
As you pull out the rod, tilt it up & wriggle it, it is only a peg in a blind hole.
Dr Terry.
Hi Les, I'll bow to Terry's much greater experience with HEI dizzys and say "follow his advice". When you come to wire up your new dizzy, have a look here: http://gallery.oldholden...lue_Electronic_Ignition/Greg has done
Hmmm ok i give up, I wiggled and jiggled and pushed and wiggled some more, but it wont budge, I ended up breaking the ring on top of the plate with the 6 triangle shaped magnet things on it, so there goes that idea, have to find another dizzy now
