Have found a HZ Van for sale, guy says it is sandman, dont have tag numbers yet, what would i be looking for to tell if its a genuine sandman? Thanks oh Also, did sandmans have side windows at all? or would they have been added later
side windows were optional these were the smaller type and 4 were fitted,the larger type would be after market
Unfortunately my website is deead at the moment, due to the hoster pulling the pin AND the current DSL wholesaler (Veridas) having major issues (I'm on my old dialup at present). When it's up and going again it tells you everything you will need to know |
i have a book that lets me tell you from the vin plates give me a ring on 0417936731
You cannot always identify a sandman from the ID plates. You can often tell it's not a Sandman though. |
As the others have said, there is a a bit involved, and Byrons site is brilliant, but you can do a quick check for things like licensed to seat 2 on the compliance plate, the remains of the metal thingy on the inside, above the upper tailgate which secure
Joined: 3/03/2005(UTC) Posts: 287 ![Australia Australia]()
Door trims should have horisontal ribing, Full roof linning, Courtesy lamps under dash for driver and pasenger foot wells. Black/ yellow needle GTS dash with a fuel bowser as fuel symbol GTS steering wheel with plan horn cap. GTS body coloured side mirro
ive owned a HX and a HZ Kingwood. they also have full hood lining and courtesy lights under the dash.But do surf Byrons site,very good site.
