#1 Posted : Wednesday, 18 February 2004 6:25:57 PM(UTC)
i've cracked a disk and have brought new pair, how do i separate the disk from the axle?
#2 Posted : Wednesday, 18 February 2004 8:30:21 PM(UTC)
You have to take the axles out, have teh wheel studs pressed out, Then the disks can be removed. (disk is held on behind the axle flange. new disk put on and studs pressed back into place.
#3 Posted : Thursday, 19 February 2004 6:26:12 PM(UTC)
thanks nathan, so my biggest problem is getting the studs pressed out or do you just put a wheel nut on and tap with hammer and if so would i be best to use new studs when finished?
cheers,
dave.
#4 Posted : Thursday, 19 February 2004 11:51:40 PM(UTC)
Best to get tehm pressed out properly. Some people just flog them out with a hammer and tighten them back in with the wheel nut but it's not real good. Use new studs if the knurling or threads are stuffed. "Nice" products make the studs.
