#1 Posted : Tuesday, 31 October 2006 5:01:29 AM(UTC)
Does anyone know what sealer to use when installing
tail lights on a HT, also when bolting in the fuel tank,
looks like the same stuff used on both, when it's old it's
white and chalky..
Thanks, Paul
#2 Posted : Tuesday, 31 October 2006 11:15:05 AM(UTC)
Unless doing a concourse restoration, I'd be using one of the Sikaflex range.
If you are doing a concourse resto, no idea...sorry.
Cheers...Dave
#3 Posted : Wednesday, 1 November 2006 3:28:36 AM(UTC)
Hi Dave,
Thanks for the reply, not heard of Sikaflex, will find out more
about it from my Autoparts store...
For the fuel tank I guess it doesn't matter so much as
it's generally not visible but the tail lights are a different
thing as the seal
#4 Posted : Wednesday, 1 November 2006 8:06:30 AM(UTC)
The GMH sealer we have at work is malleable and remains so for months if not years.Try not to use a sealer with an acidic cure.The acidic cure can help start corrosion.
#5 Posted : Wednesday, 1 November 2006 10:01:47 AM(UTC)
Sorry Paul, I missed the Fuel Tank bit...I thought they had Mastick as the sealer around the tanks. At least, they did in the LJ's and such like that I pulled apart.
I remember the sealer around the tail-lights being white. Maybe Sikaflex do a white se
Edited by user Wednesday, 1 November 2006 10:02:35 AM(UTC)  | Reason: Not specified
#6 Posted : Friday, 10 November 2006 2:22:57 AM(UTC)
Thanks to all for the tips on the sealer, sorry I've not been
at this forum for a week or so, I will go hunting for some tomorrow
keeping in mind your advice
Cheers Paul
hg350gts Offline
#7 Posted : Friday, 10 November 2006 3:53:41 AM(UTC)
hg350gts
You have been a member since:: 28/09/2006(UTC)
I agree with Qute
I use sikaflex 221? or something, unreal stuff and its available in black and white.. I think its RRP around $12 a tube.. Cures through oxygen diffusion..
Munromad2004 Offline
#8 Posted : Friday, 10 November 2006 9:42:10 AM(UTC)
Munromad2004
I spent over an hour trying to remove a set of HK GTS tail lights last weekend.
Whatever they used back then had set as hard as a rock and 30 odd years later it still wasn't letting go without a fight.
I was so afraid of breaking the lights but I manage
Guest (8)
