Rimmo Offline
#1 Posted : Tuesday, 7 November 2006 4:56:40 AM(UTC)
Rimmo
I've got a 40 thou over 308 I'm freshening up with new rings, bearings, etc. I want to run a berri brush through the bores to break the glaze, do I use a 4 inch or a 4.5 inch flex hone? and what grit do I use for std iron rings? moly rings? any advice would be appreciated.
ozchevy Offline
#2 Posted : Tuesday, 7 November 2006 4:19:27 PM(UTC)
ozchevy
Views messages in topic : 495
This is something best left to a Engine reconditioning shop with a Sunnen Engine honing machine.
The reason I say this, is because the bore needs to be flooded with cutting oil while the hone is in operation. If the glaze is hard a flexible spring loade
Rimmo Offline
#3 Posted : Wednesday, 8 November 2006 12:53:30 AM(UTC)
Rimmo
Yeah no sweat and thanks, I understand thats the correct way to do it. This motor is only a temporary fix to get me going for another twelve months while I build another. As this block is near the limit I didn't want to go to the expense of a full rebuild
