#1 Posted : Wednesday, 29 November 2006 4:09:10 AM(UTC)
Views messages in topic : 43,977
ok, could someone please confirm the piston positions for a 350 chev, standing in front , are the piston positions :
right front is piston 1
right 2nd is piston 2
right 3rd is piston 3
right rear is piston 4
left reat is piston 5
left 3rd is piston 6
left 2nd is piston 7
left front is piston 8
ive got $50 on it
#2 Posted : Wednesday, 29 November 2006 4:14:01 AM(UTC)
To confirm, this is the position to install new pistons , not firing order.
#3 Posted : Wednesday, 29 November 2006 4:53:02 AM(UTC)
I FOUND OUT SO FYI !!!
Chevrolet V8 Cylinder Positions; Top View
Front LEFT 2 4 6 Rear 8
Front RIGHT1 3 5 Rear 7
AND FOR YOU INFO HOLDENS
The cylinder positions are sometimes written on the inlet manifold.
Holden R
#4 Posted : Wednesday, 29 November 2006 7:00:03 AM(UTC)
Matt, just look at the engines. It's obvious. One cylinder head 'leads' the other ie one is further forward than the other. One bank is odd, one bank is even. The bank with the head further forward starts as cylinder 1. The other side as cylinder 2. All 2
#5 Posted : Wednesday, 29 November 2006 7:24:08 AM(UTC)
LS1/2 follow the SBC numbering.
GM products have always run the odd & even bank numbering system (so if you look at a crank, all the rod journals are 1-8 sequentially.
I think it is some ford or mopar units that number them 1-4 & then 5-8 down each
#6 Posted : Wednesday, 29 November 2006 6:26:57 PM(UTC)
THANKS BYRON, ITS ALL COMMON SENSE !!
THE RIGHT CYLINDER IS AROUND 15MM FURTHER FORWARD THAN THE LEFT.
THANKS
I'LL BE BACK WITH MY NEXT REBUILD PROBLEM !!!!!
MATT
This page was generated in 0.127 seconds.
