#1 Posted : Friday, 22 December 2006 5:39:04 AM(UTC)
Hi i have a 1996 vs exectutive commodore v6 3.8 no modifactaions at all compleetly stock the problem im having is when i put the foot down a little bit the car jerks alot i no its not the injectors/gearbox if any one has any ideas on what else it could be theat would be much apreciated thanks alot.
#2 Posted : Friday, 22 December 2006 10:10:17 AM(UTC)
Exhaust oxygen sensor, intake air pressure sensor, spark plugs, crappy old fuel, one ignition coil breaking down, loose wire . . . . . . flux capacitor may not be geting the correct gigaherts. Good luck.
#3 Posted : Friday, 22 December 2006 9:15:25 PM(UTC)
An easy test to do is to start and run the car at night with the bonnet open. It needs to be pitch black, no lights at all, but you'll get a good idea if any of the ignition leads or boots are faulty.
Hope this helps.
#4 Posted : Friday, 22 December 2006 9:41:11 PM(UTC)
Hi Matt.
The most common fault on VS V6 is either crook leads or plugs. Go to you Holden dealer & buy genuine leads & fit plugs of your choice (gap them at 1.3mm), then go from there. The electronics on VS are pretty good (much better than VN/VP).
D
