#1 Posted : Monday, 15 January 2007 6:37:25 PM(UTC)
can the head gaskets be installed wrong on a 307 & would this cause overheating ?
#2 Posted : Monday, 15 January 2007 10:27:33 PM(UTC)
If you've used 305 Chev heads then yes. You need 305 head gaskets for a 305 head on a 283 or 307. 4" bore gaskets don't seal the water jackets correctly. If the heads are proper 307 or any 4" bore head then that isn't your problem.
____________________
#3 Posted : Tuesday, 16 January 2007 12:35:57 AM(UTC)
thanks byron, it was just a thought as i don`t know who did what to the car before i bought it. has 307/350 heads
