Hello all. I have a auto bodied EJ Holden. I was given a 161 red motor and 3 speed box. I had the HR Front end already. Now my problem is as this was auto to start and it was fully pulled apart when i got it I have no idea how to do the cluch setup from the pedal to the fork to enable me to use the clutch. Is it cable or hydraulic or what can I use. ON a tight budget unfortunately. If anyone has pics to that would be great. parts even better
Thanks: 1 times Was thanked: 242 time(s) in 216 post(s)
You will need a manual pedal set-up, plus m/cyl, slave cyl & plumbing.
The holes are already in the firewall for the m/cyl mount.
The slave cylinder mounts straight onto the bell housing.
Rather than copy the factory hose & pipe arrangement, it would be easier to use the HD/HR flexible hose which runs from the m/cyl directly to the slave.
Dr Terry |
Thanks: 1 times Was thanked: 601 time(s) in 568 post(s)
I'm assuming the 3spd you have is a crash box? Or is it an all synchro from HK-HG? How are you going to shift it? Column or floor shift?
Have the engine mount brackets been moved on the HR front end to suit the earlier Holden? |
I have done the engine mount swap already and the sump change to. all i needed to figure out was how to set the clutch up from the pedal box which i already have also.not to sure if crash or syncro. the box came with the engine. I also have a floor shift for it to.
and thanks Dr Terry. I will look at what I have and what I need
What did the engine come from? 161 could be HR, HK, HT or HG. HR was crash box, HK was either and HT-HG is all synchro. |
Joined: 2/02/2009(UTC) Posts: 567  ![Australia Australia]() Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 32 times Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: lytec  I have done the engine mount swap already and the sump change to. all i needed to figure out was how to set the clutch up from the pedal box which i already have also.not to sure if crash or syncro. the box came with the engine. I also have a floor shift for it to. If I remember correctly, the syncro box need some mods to the floor to fit? For a speedway car, a big hammer sufficed. |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
Originally Posted by: Premier 350  Originally Posted by: lytec  I have done the engine mount swap already and the sump change to. all i needed to figure out was how to set the clutch up from the pedal box which i already have also.not to sure if crash or syncro. the box came with the engine. I also have a floor shift for it to. If I remember correctly, the syncro box need some mods to the floor to fit? For a speedway car, a big hammer sufficed. No, not required in an EJ/EH auto body. The hump is already large enough for most conversions. Dr Terry |
 2 users thanked Dr Terry for this useful post.
I am not to sure at the moment what car it was out of. I can try find the number and reference it on the weekend. Same with the box. I have put an album (didnt knwo how to attach to the convo sorry) with a couple of pics but dont know if you can tell by them or not. If not how do i know which box it is.
