lytec Offline
#1 Posted : Tuesday, 21 July 2020 6:55:49 PM(UTC)
lytec
Hello all. I have a auto bodied EJ Holden. I was given a 161 red motor and 3 speed box. I had the HR Front end already. Now my problem is as this was auto to start and it was fully pulled apart when i got it I have no idea how to do the cluch setup from the pedal to the fork to enable me to use the clutch. Is it cable or hydraulic or what can I use. ON a tight budget unfortunately. If anyone has pics to that would be great. parts even better
#2 Posted : Wednesday, 22 July 2020 10:01:37 AM(UTC)
You will need a manual pedal set-up, plus m/cyl, slave cyl & plumbing.
The holes are already in the firewall for the m/cyl mount.
The slave cylinder mounts straight onto the bell housing.
Rather than copy the factory hose & pipe arrangement, it would be easier to use the HD/HR flexible hose which runs from the m/cyl directly to the slave.
#3 Posted : Wednesday, 22 July 2020 11:49:44 AM(UTC)
Was thanked: 632 time(s) in 594 post(s)
I'm assuming the 3spd you have is a crash box? Or is it an all synchro from HK-HG? How are you going to shift it? Column or floor shift?
Have the engine mount brackets been moved on the HR front end to suit the earlier Holden?
lytec Offline
#4 Posted : Wednesday, 22 July 2020 1:46:50 PM(UTC)
lytec
I have done the engine mount swap already and the sump change to. all i needed to figure out was how to set the clutch up from the pedal box which i already have also.not to sure if crash or syncro. the box came with the engine. I also have a floor shift for it to.
lytec Offline
#5 Posted : Wednesday, 22 July 2020 1:47:36 PM(UTC)
lytec
and thanks Dr Terry. I will look at what I have and what I need
#6 Posted : Wednesday, 22 July 2020 2:05:43 PM(UTC)
What did the engine come from? 161 could be HR, HK, HT or HG. HR was crash box, HK was either and HT-HG is all synchro.
Premier 350 Offline
#7 Posted : Wednesday, 22 July 2020 11:23:05 PM(UTC)
Premier 350
If I remember correctly, the syncro box need some mods to the floor to fit? For a speedway car, a big hammer sufficed.
#8 Posted : Thursday, 23 July 2020 7:34:12 AM(UTC)
No, not required in an EJ/EH auto body. The hump is already large enough for most conversions.
 2 users thanked Dr Terry for this useful post.
Smitty2 on 23/07/2020(UTC), lytec on 27/07/2020(UTC)
lytec Offline
#9 Posted : Friday, 24 July 2020 4:16:05 PM(UTC)
lytec
I am not to sure at the moment what car it was out of. I can try find the number and reference it on the weekend. Same with the box. I have put an album (didnt knwo how to attach to the convo sorry) with a couple of pics but dont know if you can tell by them or not. If not how do i know which box it is.
