Taztiger4 Offline
#1 Posted : Tuesday, 29 November 2022 10:22:27 AM(UTC)
Taztiger4
HI all
Any trick to replacing both the PS lines ? (253)
Does the pump need to be primed or anything or just fill & go
#2 Posted : Tuesday, 29 November 2022 10:43:08 AM(UTC)
Originally Posted by: Taztiger4 Go to Quoted Post
HI all
No tricks, just make sure you have the correct hoses. The HJ uses the early high pressure hose with a flare type fitting at each end.
Fill it up, put the cap on & start the engine, let it idle & turn the steering wheel slowly from lock to lock. Turn it off to top it up.
Initially the fluid will tend to aerate (fizz up) a bit & the pump will whine, but don't worry, just let it sit & start it up later.
Taztiger4 Offline
#3 Posted : Tuesday, 29 November 2022 10:46:17 AM(UTC)
Taztiger4
HI all
cheers, is there a drain port ? or just crack the hoses, let it bleed & into it
#4 Posted : Tuesday, 29 November 2022 11:52:09 AM(UTC)
HI all
No drain port, no bleeding required. The fluid goes from the reservoir, into the pump, then to the box & back to the reservoir. It "self bleeds".
Taztiger4 on 29/11/2022(UTC)
KBM Offline
#5 Posted : Tuesday, 29 November 2022 11:57:12 AM(UTC)
KBM
No drain plug just crack the hoses and let them drain into a bucket.
 1 user thanked KBM for this useful post.
