Joined: 15/09/2022(UTC) Posts: 73 Location: Perth Thanks: 33 times
HI all
Any trick to replacing both the PS lines ? (253)
Does the pump need to be primed or anything or just fill & go
Does the pump need to be primed or anything or just fill & go No tricks, just make sure you have the correct hoses. The HJ uses the early high pressure hose with a flare type fitting at each end. Fill it up, put the cap on & start the engine, let it idle & turn the steering wheel slowly from lock to lock. Turn it off to top it up. Initially the fluid will tend to aerate (fizz up) a bit & the pump will whine, but don't worry, just let it sit & start it up later. Dr Terry |
Does the pump need to be primed or anything or just fill & go No tricks, just make sure you have the correct hoses. The HJ uses the early high pressure hose with a flare type fitting at each end. Fill it up, put the cap on & start the engine, let it idle & turn the steering wheel slowly from lock to lock. Turn it off to top it up. Initially the fluid will tend to aerate (fizz up) a bit & the pump will whine, but don't worry, just let it sit & start it up later. Dr Terry cheers, is there a drain port ? or just crack the hoses, let it bleed & into it
Originally Posted by: Taztiger4 Originally Posted by: Dr Terry Originally Posted by: Taztiger4 HI all
Does the pump need to be primed or anything or just fill & go No tricks, just make sure you have the correct hoses. The HJ uses the early high pressure hose with a flare type fitting at each end. Fill it up, put the cap on & start the engine, let it idle & turn the steering wheel slowly from lock to lock. Turn it off to top it up. Initially the fluid will tend to aerate (fizz up) a bit & the pump will whine, but don't worry, just let it sit & start it up later. Dr Terry cheers, is there a drain port ? or just crack the hoses, let it bleed & into it No drain port, no bleeding required. The fluid goes from the reservoir, into the pump, then to the box & back to the reservoir. It "self bleeds". Dr Terry |
Joined: 21/04/2017(UTC) Posts: 293 Location: Tolmie Thanks: 2 times Was thanked: 24 time(s) in 24 post(s)
No drain plug just crack the hoses and let them drain into a bucket.
1 user thanked KBM for this useful post.
