#1 Posted : Saturday, 7 January 2006 7:58:37 AM(UTC)
gday. put a new clutch in the ute about 2 months ago. put a heavy duty 308 one behind the 253, along with pressure plate and thrust bearing, went fine for a month or so but now seems to shudder off the line. no amount of adjustments would get rid of for more that 4 or 5 pushes. pulled the rat trap apart cleaned it, new springs still did. got new rat trap put it in lasted a bit longer but startin to do it again!! any suggestions??
crowe Offline
#2 Posted : Saturday, 7 January 2006 9:50:37 PM(UTC)
crowe
I hope you didnt bend any of the clutch fingers when trying to put the transmission back in.dont ever let the input shaft rest the weight of the g/box on the fingers because it wont slide through and you get tired of holding the heavy weight.
#3 Posted : Sunday, 8 January 2006 8:09:08 AM(UTC)
Did you get flywheel machined.
if it ain't broke we can improve it.
#4 Posted : Sunday, 8 January 2006 11:23:00 AM(UTC)
I'm with vzgen3 always at least check the surface of the flywheel it may not need machining just be glazed run some emery paper over it, then put a straightedge across it, if you see light in the middle it needs machining, anyway for the cost involved it
#5 Posted : Sunday, 8 January 2006 10:22:11 PM(UTC)
One other thing I forgot to mention make sure it has a spigot bearing fitted and make sure it isn't to loose on gearbox input shaft.
#6 Posted : Monday, 9 January 2006 11:55:49 PM(UTC)
yeah sorry forgot to add i did get the flywheel machined. also have been noticing the last few days its fine when you first cold start and then starts gettin shuddery as the car warms up a little bit. the rubber mount that goes onto the crossmember is fai
#7 Posted : Tuesday, 10 January 2006 7:26:12 AM(UTC)
Soft mount can cause shudder but it wouldn't make a difference hot or cold,when installing gearbox important not to let gearbox hang from clutch plate when not fully installed this can possibly cause problem.
#8 Posted : Tuesday, 10 January 2006 6:38:52 PM(UTC)
allright cool. thanks guys
#9 Posted : Sunday, 15 January 2006 11:23:41 AM(UTC)
Is it a new clutch or recon one? I have found reconm ones often give trouble with the springs coming loose. Also the symptom is like oil on the plate. You sure you don't have an oil leak?
#10 Posted : Monday, 13 March 2006 9:46:35 PM(UTC)
sorry to bring up an old thred but its still happening!!!!
yes it was a brand new setup. ive sinve replaced the rear gearbox mount which was buggered but didnt make a difference at all.
talked to the bloke at the clutch shop. he said to check to mak
#11 Posted : Tuesday, 14 March 2006 10:03:08 AM(UTC)
Are you using a plastic throw out bearing carrier? If so get rid of it and get a steel one. A mate had shuddering problems with a new clutch and was advised on the steel carrier and it fixed the problem. TD
#12 Posted : Friday, 12 May 2006 10:10:28 PM(UTC)
How much does it cost to get a flywheel machined? Anyone know a good place to get it done in melb?
#13 Posted : Sunday, 14 May 2006 11:46:11 PM(UTC)
If u have your clutch pedel adjustment over adjusted it will be fine antil heat gets into it, also are u running a sigle or duel exhaust and wgere does it run in relation to the bellhousing?
I'm running a 308 with a commadore bellhousing and cable(as i c
classic oz wreck Offline
#14 Posted : Monday, 15 May 2006 6:51:38 AM(UTC)
classic oz wreck
biggest problems i see as a seller of parts for hodens is....hx z early style pedels are half cable with mechanical on the bottom...clutch pedal for these is a hook up arrangement and is unique to this arrangement...both 6 cylinder and v8 is the same peda
www.classicozwreck.com.au
