#1 Posted : Tuesday, 7 February 2006 6:06:37 PM(UTC)
I want to make my vl bumpers 1 piece instead of the 3 (2 corners and a centre)they are now. Have tried bog which resulted in a fine crack appearing. Tried enlarging the join and filling with fibre glass resin and fine chopped glass which also resulted in a fine crack. Any ideas on how to go about it?
Saw it in a magazine liked the look and as always its only after you find out that it ain't that easy. Damn magazines.
#2 Posted : Tuesday, 7 February 2006 7:20:34 PM(UTC)
I think you would also need to re-inforce the joint from behind the bar by fibreglassing over the back of the join & extending the 'glass some 100-200mm along each part past the joint, then fill up the gap on the outside of the bar.
The other method wo
peter_flane Offline
#3 Posted : Wednesday, 8 February 2006 7:54:28 AM(UTC)
peter_flane
The best way would be to get new bumper sections with no paint on them and then get them plastic welded together.
This page was generated in 0.118 seconds.
