I want to make my vl bumpers 1 piece instead of the 3 (2 corners and a centre)they are now. Have tried bog which resulted in a fine crack appearing. Tried enlarging the join and filling with fibre glass resin and fine chopped glass which also resulted in a fine crack. Any ideas on how to go about it? Saw it in a magazine liked the look and as always its only after you find out that it ain't that easy. Damn magazines.
I think you would also need to re-inforce the joint from behind the bar by fibreglassing over the back of the join & extending the 'glass some 100-200mm along each part past the joint, then fill up the gap on the outside of the bar.
The other method wo |
The best way would be to get new bumper sections with no paint on them and then get them plastic welded together. |
