#1 Posted : Monday, 10 July 2006 2:36:10 AM(UTC)
Hi to all.
I was reading a querie from another site about airconditioning and a few of the replies mention a dr terry who has a lot to do with the above mentioned.
Is there any detailed installations on this site for installing an air conditioner into a HR or other site.
Or dose dr terry have a contact.
HR ute.
#2 Posted : Monday, 10 July 2006 4:32:05 AM(UTC)
Dr Terry is on this site.
You can click on the "send email" link in his profile here:
http://www.fastlane.com....e.asp?mode=display&id=40
A l
#3 Posted : Monday, 10 July 2006 8:41:35 AM(UTC)
Thank you mick.
email sent regards hr61
hail damage in Qld
always wear a helmet
sgo Offline
#4 Posted : Tuesday, 11 July 2006 2:38:25 AM(UTC)
sgo
I'm trying to do something similar.
Does anyone know how to tell if the TX valve on an older under-dash unit is compatible with a new compressor?
#5 Posted : Tuesday, 11 July 2006 2:51:29 AM(UTC)
Hi sgo.
As soon as iget a reply from dr terry I will let you know.
#6 Posted : Tuesday, 11 July 2006 5:41:31 AM(UTC)
Hi Guys.
I've done dozens of HD/HR a/cond installations & they are probably one of the more difficult Holden model series to do. There are 2 problems.
1st is lack of a good off-the-shelf mount/drive kit to suit a modern rotary style compressor. To
sgo Offline
#7 Posted : Tuesday, 11 July 2006 7:02:02 AM(UTC)
sgo
Thanks for that run-down Dr.Terry.
I think I can cover all of what you have suggested.
The under-dash evaporator is complete with the TX valve so I assume they are matched, but is there any way of telling if it's compatable with R134a gas?
#8 Posted : Tuesday, 11 July 2006 5:45:59 PM(UTC)
Thank you for the reply and information
Moving the engine back, was the tail shaft a problem
hail damage in Qld
