Hi to all. I was reading a querie from another site about airconditioning and a few of the replies mention a dr terry who has a lot to do with the above mentioned. Is there any detailed installations on this site for installing an air conditioner into a HR or other site. Or dose dr terry have a contact. HR ute.
Thanks: 1 times Was thanked: 35 time(s) in 33 post(s)
Dr Terry is on this site. You can click on the "send email" link in his profile here: http://www.fastlane.com....e.asp?mode=display&id=40Cheers, Mick _______________________________________________________________ A l |
Thank you mick. email sent regards hr61
hail damage in Qld always wear a helmet
I'm trying to do something similar. Does anyone know how to tell if the TX valve on an older under-dash unit is compatible with a new compressor?
Hi sgo. As soon as iget a reply from dr terry I will let you know.
Thanks: 1 times Was thanked: 244 time(s) in 218 post(s)
Hi Guys.
I've done dozens of HD/HR a/cond installations & they are probably one of the more difficult Holden model series to do. There are 2 problems.
1st is lack of a good off-the-shelf mount/drive kit to suit a modern rotary style compressor. To |
Thanks for that run-down Dr.Terry. I think I can cover all of what you have suggested. The under-dash evaporator is complete with the TX valve so I assume they are matched, but is there any way of telling if it's compatable with R134a gas?
Thank you for the reply and information Moving the engine back, was the tail shaft a problem
