7 Pages<1234>»
Titmar Offline
#21 Posted : Monday, 21 August 2006 2:50:32 PM(UTC)
Titmar
Does any one know if the VK Commadore Diff will fit into a WB ute.
Just a thought
THANKS
TITMAR
#22 Posted : Tuesday, 22 August 2006 8:18:07 AM(UTC)
The whole back axle or just the diff? The axle won't fit too narrow and you have to modify the spring mounts. A VN onwards will be almost perfect fit but will still need the mounts modified.
#23 Posted : Tuesday, 22 August 2006 8:18:07 AM(UTC)
The whole back axle or just the diff? The axle wont fit too narrow and you have to modify the spring mounts. A VN onwards will be almost perfect fit but will still need the mounts modified.
kraul Offline
#24 Posted : Wednesday, 23 August 2006 10:58:30 PM(UTC)
kraul
Jus give me ur email and il send u the diagram 2nite
Titmar Offline
#25 Posted : Friday, 25 August 2006 6:30:00 AM(UTC)
Titmar
The hole think ,just thought since the one in the ute is u/s
I thought well I have one can I use it. I didnt know about the VN,Did they come out with disc ass ends .
thanks
Titmar
#26 Posted : Friday, 25 August 2006 9:19:30 AM(UTC)
titmar:
I've just finished this conversion in my LC Torana, goes great.
this might come in handy for the fuel pump relay.
http://www.oldholdens.co...sion/efirelay-wiring.jpg
Sammy's site is great for info
Edited by user Friday, 25 August 2006 9:23:31 AM(UTC)  | Reason: Not specified
#27 Posted : Friday, 25 August 2006 9:19:30 AM(UTC)
titmar:
Ive just finished this conversion in my LC Torana, goes great.
Sammys site is great for info
http://www.oldholdens.com
#28 Posted : Friday, 25 August 2006 9:26:13 AM(UTC)
The VN onwards all had disk rears. the width disk to disk is within a smick of the HQ-WB.
Titmar Offline
#29 Posted : Sunday, 27 August 2006 10:11:40 PM(UTC)
Titmar
Gday Can any body tell me the best header to put on my 3.3 EFI motor
to get the best out of the motor .
Thank
Titmar
#30 Posted : Monday, 28 August 2006 5:50:12 AM(UTC)
use the stainless steel EFI stockie they are as good as most and cheap.
Titmar Offline
#31 Posted : Monday, 28 August 2006 6:38:59 AM(UTC)
Titmar
Gday mates
I was talking to some mates about my ute and they said about puting in a surge tank , do I need one or not.
Titmar
#32 Posted : Monday, 28 August 2006 6:47:30 AM(UTC)
It is a very good idea, but not absolutely necessary. Say a bit like an oil cooler on an auto transmission. The idea of a swirl pot is to ensure you always have petrol in the pump as it is how the pump is lubricated. One will cost you about $125 from Amer
kraul Offline
#33 Posted : Monday, 28 August 2006 9:11:51 PM(UTC)
kraul
For ease it probably best to put in a surge tank and just use a lift pump then the efi. its not as neat but can be done easily. a guy on ebay makes custom surge tanks for a reasonable price to your specs. Geting an efi tank to fit is not fun but cvan be d
Titmar Offline
#34 Posted : Tuesday, 5 September 2006 6:35:34 AM(UTC)
Titmar
Hello its me again, just a quick question do I have to drill the dip stick hole out in the black motor or is there a plug in it.
Titmar
#35 Posted : Tuesday, 5 September 2006 9:09:18 AM(UTC)
The plug kmocks out but you have to reach it by taking the sump off and using a long rod to get a it.
The dipstick tube from the earlier motor will have to be fitted, I had real problems getting it to seal it kept leaking oil, also it has to go in a part
Titmar Offline
#36 Posted : Tuesday, 5 September 2006 11:07:57 AM(UTC)
Titmar
Thanks johnperth I will do that tomorrow .
Titmar
Titmar Offline
#37 Posted : Monday, 18 September 2006 7:16:26 AM(UTC)
Titmar
Hello out thier I would like to know if a vn disc ass end fit a wb ute or is it to narrow.
always remember BROCKIE 05
Titmar
#38 Posted : Monday, 18 September 2006 9:25:21 AM(UTC)
VN onwards fit almost perfectly but of course you have to modify the brackets etc and I believe some messing about with the handbrake setup.
Titmar Offline
#39 Posted : Thursday, 28 September 2006 10:41:11 PM(UTC)
Titmar
Hello Again , Question I have just been offered a 5 speed gearbox out of a vn wagon would this be better than a supra 5 or sould I stick with the supra 5
Titmar
Mr Void Offline
#40 Posted : Friday, 29 September 2006 7:51:59 PM(UTC)
Mr Void
Stick with the supra box.
___________________
Why are you reading this, you should be looking up there^^
___________________
7 Pages<1234>»
