DJBOOBY Offline
#1 Posted : Tuesday, 29 August 2006 7:53:04 AM(UTC)
DJBOOBY
hi need to know if there a place i can send my xf flywheel to be repaired with new ring gear as well as mechined and balance as im puting behind a worked 4.1
live nere Wagga Wagga nsw (Tumut)
#2 Posted : Friday, 1 September 2006 7:10:25 AM(UTC)
any place that does clutches should have no problem doing this sort of thing. the balancing will need to be done at the same time as the motor, as the crank rods pistons and flywheel all need to be balanced too
DJBOOBY Offline
#3 Posted : Saturday, 2 September 2006 3:39:50 AM(UTC)
DJBOOBY
yep motor will be balance the one im getting has a full balance, race poistons, lager valves / v/springs, crow cam,crow timing chain,race bearings, race gasket set,
i know flywheel should be on when doing balance but motor was built some time back
#4 Posted : Thursday, 23 November 2006 9:42:08 PM(UTC)
take it 2 a clutch joint
#5 Posted : Thursday, 23 November 2006 11:40:40 PM(UTC)
You can replace the ring gear yourself - if you have oxy gear. Then all you need to do get it machined.
#6 Posted : Sunday, 26 November 2006 10:49:11 AM(UTC)
You don't need oxy or anything fancy. Use a good sharp cold chisel, crack the ringgear off, helps to start with a hacksaw cut,on about 4 parts of the new ring gear polish a small area, put the new ring gear in the oven or use a blow torch or lpg torch, he
#7 Posted : Sunday, 26 November 2006 10:50:39 AM(UTC)
Oh as misc said make sure you get it machined if it needs a new ring gear it is sure to be hollowed out, and the new clutch will not work properly.
