howdy all, I was recently told that if your original motor is not in use you can get one re stamped with that number. Is this possible or more to the point is it legal?
it is illegal & how can you tell if your original engine No is in use or not
HOLDEN The Great Way to Move |
HOLDEN T |
You only have to be in front at the end of the race. |
its only illegal if you get caught, i used to work on a production line stamping the engine numbers in the early 90`s and used to file off by hand at least 2 errors per day and restamp them so how would anyone know if you didnt tell them and used the corr
Here's a tip - I've got mates in Queensland Transport & the Queensland Police Service, so I'm not just on a soap-box here, it's all true. Re-stamping your block is not only illegal, but dumb - it's re-birthing. If you're trying to pass your car as off as
settle down guys thats exactly why i asked. I couldn't see how it was possible either.But the guy telling me about it was dead set serious and whats worse is he is right into restoring engines, thats his profession. So guess i'll be finding someone else.
If you REALLY want the original motor back in the car, get the split bore re-sleeved...
Cheers...Dave
Fair enough - I thought you were going to do it.
The Beige Hornet.
Weld up and sleeve it. People say it a bogie thing to do. i look at this way. How many diesels are sleeved. Cats Cummins. I dont remember comming across a heavy industry diesel thats not sleeved. compression ratio of 22-28 to 1 then theres a turbo on top
When I bought my tonner it was unlicences and the engine had a number but there was a tag rivetted over it with another number, this tag had the engine reconditioners details on it. when I regoed it the RTA took the tag as the number not the stamped numbe
On a kind of related note.. I have also been told that if your car had an accident and the chassis was bent, you are allowed to restamp your replacement chassis with the original number..?? As long as you can prove to the RTA that the old chassis is out o
In queensland you can get a 'surrogate' vin number that the transport department generate & then you stamp it on. I've got no idea if they do the same for engines.
The Beige Hornet.
They do in NSW. Same numbers as re-issued chassis numbers. Looks like NxxxxxP. |
you cant restamp a VIN number, thats how they can tell if you are using a chassis that is a satutaury write off. if you put a new chassis under a car, in the eyes of the authourities, it becomes the car that the chassis is from.
