#1 Posted : Friday, 6 October 2006 6:57:01 PM(UTC)
howdy all, I was recently told that if your original motor is not in use you can get one re stamped with that number. Is this possible or more to the point is it legal?
#2 Posted : Saturday, 7 October 2006 12:07:54 AM(UTC)
it is illegal & how can you tell if your original engine No is in use or not
JBM Offline
#3 Posted : Saturday, 7 October 2006 1:07:16 AM(UTC)
JBM
HOLDEN T
#4 Posted : Saturday, 7 October 2006 3:49:55 AM(UTC)
its only illegal if you get caught, i used to work on a production line stamping the engine numbers in the early 90`s and used to file off by hand at least 2 errors per day and restamp them so how would anyone know if you didnt tell them and used the corr
#5 Posted : Saturday, 7 October 2006 5:24:25 AM(UTC)
Here's a tip - I've got mates in Queensland Transport & the Queensland Police Service, so I'm not just on a soap-box here, it's all true. Re-stamping your block is not only illegal, but dumb - it's re-birthing. If you're trying to pass your car as off as
#6 Posted : Saturday, 7 October 2006 6:45:12 AM(UTC)
settle down guys thats exactly why i asked. I couldn't see how it was possible either.But the guy telling me about it was dead set serious and whats worse is he is right into restoring engines, thats his profession. So guess i'll be finding someone else.
#7 Posted : Saturday, 7 October 2006 9:35:13 AM(UTC)
If you REALLY want the original motor back in the car, get the split bore re-sleeved...
Cheers...Dave
#8 Posted : Sunday, 8 October 2006 1:51:33 AM(UTC)
Fair enough - I thought you were going to do it.
The Beige Hornet.
#9 Posted : Sunday, 8 October 2006 9:48:56 AM(UTC)
Weld up and sleeve it. People say it a bogie thing to do. i look at this way. How many diesels are sleeved. Cats Cummins. I dont remember comming across a heavy industry diesel thats not sleeved. compression ratio of 22-28 to 1 then theres a turbo on top
#10 Posted : Sunday, 8 October 2006 10:15:34 AM(UTC)
When I bought my tonner it was unlicences and the engine had a number but there was a tag rivetted over it with another number, this tag had the engine reconditioners details on it. when I regoed it the RTA took the tag as the number not the stamped numbe
hainzy Offline
#11 Posted : Monday, 9 October 2006 2:39:22 AM(UTC)
hainzy
On a kind of related note.. I have also been told that if your car had an accident and the chassis was bent, you are allowed to restamp your replacement chassis with the original number..?? As long as you can prove to the RTA that the old chassis is out o
#12 Posted : Monday, 9 October 2006 6:48:36 PM(UTC)
In queensland you can get a 'surrogate' vin number that the transport department generate & then you stamp it on. I've got no idea if they do the same for engines.
The Beige Hornet.
#13 Posted : Monday, 9 October 2006 8:53:31 PM(UTC)
They do in NSW. Same numbers as re-issued chassis numbers. Looks like NxxxxxP.
Dylan Offline
#14 Posted : Monday, 9 October 2006 9:22:38 PM(UTC)
Dylan
you cant restamp a VIN number, thats how they can tell if you are using a chassis that is a satutaury write off. if you put a new chassis under a car, in the eyes of the authourities, it becomes the car that the chassis is from.
