#1 Posted : Thursday, 12 October 2006 4:52:58 AM(UTC)
Anyone know the tension torque specs for the VN/VP V6 engine?? i chasing the conrods/crank mains/ head/rocker gear etc...
jabba Offline
#2 Posted : Friday, 13 October 2006 3:09:59 PM(UTC)
jabba
Have the workshop manual, will have a gander tonight for you.
j
#3 Posted : Friday, 13 October 2006 3:13:20 PM(UTC)
Thnaks Heaps mate
jabba Offline
#4 Posted : Friday, 13 October 2006 10:56:28 PM(UTC)
jabba
Dude,
What series is it. There are different torque values for VN up to 11/90, VN from 11/90 (Series 2) and VP on for various bits. GIve us the nod and I can give you more torque values than you can shake a stick at from Haynes manual.
_________
#5 Posted : Saturday, 14 October 2006 5:27:40 AM(UTC)
Hey Bloke, Its 4/93 VP Commodore 3.8L V6 Auto, i have noticed that between the models there was a change between the inlet manifolds and slight changes in the cooling system. in this case the plenum chamber is swept to the sides instead of being more a ve
jabba Offline
#6 Posted : Tuesday, 17 October 2006 3:59:11 AM(UTC)
jabba
Main caps - 31 to 39 Nm (then additional 48 degrees)
Con rod - 24 to 30 Nm plus 50 degrees
Cam sprocket bolt - (single bolt) 190 to 200 Nm
Cylinder head bolts - (in sequence) 34 Nm each, then an additional 90 degrees each, then to 81 Nm.
Sequence
#7 Posted : Tuesday, 17 October 2006 6:47:06 AM(UTC)
Thanks Bloke, ur a champion, thats exactly what i'm after. maybe now i can get it out of my driveway and back to my mate. :) cheers again
jabba Offline
#8 Posted : Tuesday, 17 October 2006 1:54:44 PM(UTC)
jabba
No probs dude.
Best of luck...
