Howdy, Does anyone know if the shift on a Celica 5spd will clear a bench seat in a HG? Just had the Brougham Bench/Bucket re-covered so I don't want to lose it - any ideas? Does anyone know of a remote-shift set up available...?
The Beige Hornet.
Don't know for sure, buy one suggestion may be to get a HQ-WB Bench seat shifter stick and weld/adapt it to the Sillycar shifter stub. You'll probably not be able to move the bench fully forward though. |
Hi BH,
This has been asked a couple of times before and part of it is almost impossible to explain in words...
The Celica (assuming we are talking steel case boxes here) come with a range of shifter positions. The shifter positions are also, apparen
Dave, just for the sake of letting you know - that made perfect sense to me! I reckon you explained it quite well..
___________________ Why are you reading this, you should be looking up there^^ Joetech Tonner - coming soon! |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
The 3 spots all have a unique shifter housing casting, that you can't rotate (due to their being a slant on the rear of the box).
The Hilux position suits a commodore perfectly (comes directly up from the shifter plate, in the front half of the plate). |
quote: Originally posted by Qute
Once again, assuming you have the forward-most shifter and it still won't clear your bench Edited by user Tuesday, 24 October 2006 8:20:01 PM(UTC)
| Reason: Not specified |
Originally posted by Mr Void"Dave, just for the sake of letting you know - that made perfect sense to me! I reckon you explained it quite well.." Thanks Mr Void. When you talk about rotating and then flipping a figment of your imagination w Edited by user Wednesday, 25 October 2006 1:27:31 AM(UTC)
Sure can Dave, they are practically identical, inside & out, bar the first 1 or 2 ratios, and the variations in the shifter location & the heel on the selector rod.
A l |
