YetAnotherForum.NET Help
#1 Posted : Tuesday, 24 October 2006 3:41:01 AM(UTC)
Howdy,
Does anyone know if the shift on a Celica 5spd will clear a bench seat in a HG? Just had the Brougham Bench/Bucket re-covered so I don't want to lose it - any ideas? Does anyone know of a remote-shift set up available...?
The Beige Hornet.
#2 Posted : Tuesday, 24 October 2006 6:44:31 AM(UTC)
Don't know for sure, buy one suggestion may be to get a HQ-WB Bench seat shifter stick and weld/adapt it to the Sillycar shifter stub. You'll probably not be able to move the bench fully forward though.
#3 Posted : Tuesday, 24 October 2006 10:27:55 AM(UTC)
Hi BH,
This has been asked a couple of times before and part of it is almost impossible to explain in words...
The Celica (assuming we are talking steel case boxes here) come with a range of shifter positions. The shifter positions are also, apparen
Mr Void Offline
#4 Posted : Tuesday, 24 October 2006 11:32:14 AM(UTC)
Mr Void
Dave, just for the sake of letting you know - that made perfect sense to me! I reckon you explained it quite well..
___________________
Why are you reading this, you should be looking up there^^
Joetech Tonner - coming soon!
___________________
#5 Posted : Tuesday, 24 October 2006 4:46:35 PM(UTC)
The 3 spots all have a unique shifter housing casting, that you can't rotate (due to their being a slant on the rear of the box).
The Hilux position suits a commodore perfectly (comes directly up from the shifter plate, in the front half of the plate).
#6 Posted : Tuesday, 24 October 2006 8:18:55 PM(UTC)
Originally posted by Qute
Once again, assuming you have the forward-most shifter and it still won't clear your bench
Edited by user Tuesday, 24 October 2006 8:20:01 PM(UTC)  | Reason: Not specified
#7 Posted : Wednesday, 25 October 2006 1:26:33 AM(UTC)
Originally posted by Mr Void
"Dave, just for the sake of letting you know - that made perfect sense to me! I reckon you explained it quite well.."
Thanks Mr Void. When you talk about rotating and then flipping a figment of your imagination w
Edited by user Wednesday, 25 October 2006 1:27:31 AM(UTC)  | Reason: Not specified
#8 Posted : Wednesday, 25 October 2006 4:14:01 AM(UTC)
Sure can Dave, they are practically identical, inside & out, bar the first 1 or 2 ratios, and the variations in the shifter location & the heel on the selector rod.
A l
