red Offline
#1 Posted : Thursday, 2 November 2006 7:22:57 AM(UTC)
red
Hi. Does anyone know if Hq-Hz sedan fuel tanks are interchangable. I need to replace the one in my Hq, strange rattle when doing between 100-110kmh. Heard fuel senders may be different in later tanks (cause of the different gauges) if this is true can i take my original and swap into new tank? or do they have differnt mountings? Cheers
#2 Posted : Thursday, 2 November 2006 7:41:11 AM(UTC)
HJ onward has a bigger 16 gallon fuel tank , but should still fit using the straps that come off the later tank.
I think the senders should work , the GTS had a different sender in the tank I believe.
trubluhq Offline
#3 Posted : Thursday, 2 November 2006 11:12:21 PM(UTC)
trubluhq
Surely a rattle isnt raason enought to replace a tank. What is the rattle ?? Maybe its only the sender making a noise. Replace the sender. Maybe you have the WRONG petrol cap on it ?? Maybe the tank cant vent when the pump is sucking the juice ?? I mnow t
red Offline
#4 Posted : Friday, 3 November 2006 7:30:06 AM(UTC)
red
I have tryed removing petrol cap already. The rattle sounds as if its coming from inside or on top of tank. The fuel gauge works correctly so sender float shouldnt be hitting tank. The sender may be loose but i have to drop the tank to check, and if tank
#5 Posted : Friday, 3 November 2006 7:48:04 AM(UTC)
yes John they are , i was looking at the HJ brochure that says ` a Go Further 16 gallon tank`. -75 lt up to HZ , the WB statesman has a 91 lt tank.
#6 Posted : Friday, 3 November 2006 11:39:14 AM(UTC)
Maybe something has been dropped into the tank at some stage? Sometimes, the locking mechanism in locking petrol caps used to seize and they would be levered off with the centre of the cap usually ending up inside the tank.
I'd pull the sender, grab a
This page was generated in 0.102 seconds.
