You are a member of these groups:: Registered
Hi. Does anyone know if Hq-Hz sedan fuel tanks are interchangable. I need to replace the one in my Hq, strange rattle when doing between 100-110kmh. Heard fuel senders may be different in later tanks (cause of the different gauges) if this is true can i take my original and swap into new tank? or do they have differnt mountings? Cheers
HJ onward has a bigger 16 gallon fuel tank , but should still fit using the straps that come off the later tank. I think the senders should work , the GTS had a different sender in the tank I believe.
Surely a rattle isnt raason enought to replace a tank. What is the rattle ?? Maybe its only the sender making a noise. Replace the sender. Maybe you have the WRONG petrol cap on it ?? Maybe the tank cant vent when the pump is sucking the juice ?? I mnow t
I have tryed removing petrol cap already. The rattle sounds as if its coming from inside or on top of tank. The fuel gauge works correctly so sender float shouldnt be hitting tank. The sender may be loose but i have to drop the tank to check, and if tank
yes John they are , i was looking at the HJ brochure that says ` a Go Further 16 gallon tank`. -75 lt up to HZ , the WB statesman has a 91 lt tank.
Maybe something has been dropped into the tank at some stage? Sometimes, the locking mechanism in locking petrol caps used to seize and they would be levered off with the centre of the cap usually ending up inside the tank.
I'd pull the sender, grab a
