Howdy, Can someone tell me if the clutch used for the small (hydraulic) 3spd in HR's & HK's is the same / will fit the later big (cable) 3spd's found in HG's & HQ's...? Ta. What's the story with the small 3spds - are they any good? I assume the later, bigger ones are better....?
The Beige Hornet.
Hi Beige Hornet.
The pressure plate & throwout bearing are the same, but the clutch plate has a different centre (splines are different). The early 'crash boxes' only have synchro on 2nd & 3rd & are quite weak compared to an all-synchro HK to WB 3-spee |
Ta. I'll add a clutch plate to the shopping list then...
The Beige Hornet.
i once put a 186 from i think a hk into a ek ute using the old 3 speed and the hk clutch and plate when i started it up and tried the gears got nothing the spigot shaft past staight through the clutch without thouching it you live and learn cheers
Is there some id marking or something obvious on the 3 speed boxes to identify the early units from the later HK-WB 3 speeders or do you have to check the input shaft?
They look completely different. The all synchro looks like an aussie 4spd
