#1 Posted : Wednesday, 20 December 2006 9:02:18 PM(UTC)
Howdy,
Can someone tell me if the clutch used for the small (hydraulic) 3spd in HR's & HK's is the same / will fit the later big (cable) 3spd's found in HG's & HQ's...? Ta. What's the story with the small 3spds - are they any good? I assume the later, bigger ones are better....?
The Beige Hornet.
#2 Posted : Wednesday, 20 December 2006 9:38:42 PM(UTC)
Hi Beige Hornet.
The pressure plate & throwout bearing are the same, but the clutch plate has a different centre (splines are different). The early 'crash boxes' only have synchro on 2nd & 3rd & are quite weak compared to an all-synchro HK to WB 3-spee
#3 Posted : Thursday, 21 December 2006 6:25:44 PM(UTC)
Ta. I'll add a clutch plate to the shopping list then...
The Beige Hornet.
#4 Posted : Friday, 22 December 2006 2:02:51 AM(UTC)
i once put a 186 from i think a hk into a ek ute using the old 3 speed and the hk clutch and plate when i started it up and tried the gears got nothing the spigot shaft past staight through the clutch without thouching it you live and learn cheers
madjack Offline
#5 Posted : Saturday, 23 December 2006 1:08:54 AM(UTC)
madjack
Is there some id marking or something obvious on the 3 speed boxes to identify the early units from the later HK-WB 3 speeders or do you have to check the input shaft?
#6 Posted : Saturday, 23 December 2006 2:48:00 AM(UTC)
They look completely different. The all synchro looks like an aussie 4spd
This page was generated in 0.234 seconds.
