#1 Posted : Friday, 11 May 2007 3:21:14 AM(UTC)
I'm about to replace the pads on an '03 TS Astra hatchback for a friend.
Haven't been there before on an Astra and I'd be grateful for any instructions for removing front & rear callipers and advice as to whether the pistons are push in or screw in.
Many thanks. DS
#2 Posted : Friday, 11 May 2007 5:01:57 AM(UTC)
ther not like a norm push in tipe i think ther screw sort and you need hex keys to get the bolts undun
#3 Posted : Friday, 11 May 2007 7:00:51 AM(UTC)
Thanx for that.
stopgo Offline
#4 Posted : Friday, 11 May 2007 7:21:33 AM(UTC)
stopgo
Screw in
If they are Bosch DO NOT undo the 5 point hex bolt.
gmholdman Offline
#5 Posted : Friday, 11 May 2007 7:05:21 PM(UTC)
gmholdman
You may also have to change the discs (as from memory) they cannot be machined.
#6 Posted : Friday, 11 May 2007 10:20:48 PM(UTC)
Thanx Stopgo & gmholdman, I was looking at that 5 point bolt hand wondering whether to take it out or not ! Saved my bacon. The discs are a little worn but I think they'll be OK until next time. It's interesting that the rear pads and discs have worn more
stopgo Offline
#7 Posted : Saturday, 12 May 2007 8:02:00 AM(UTC)
stopgo
The reason why they are worn is because they are a European car
Euro cars have to conform to a TUV standard whereby they have to stop in a certain distance in relation to their weight from a given speed
The only way to do this is with high friction leve
