#1 Posted : Friday, 5 January 2007 8:29:47 PM(UTC)
hi, i own a landrover with a 186 holden motor, it pings quite bad running on 91 octane, i was just wondering what they were designed to run on from factory, here we have 91/96/and 98 octane, id like to run it on 95 as its cheaper, but stil better for it, any advice welcome..
#2 Posted : Saturday, 6 January 2007 1:18:31 AM(UTC)
It should run OK on 95, but you'll probably need to regraph a dizzy for it to run optimally. Use a dizzy and coil off any blue 6 or an EFI VK. Run full 12V to the HEI coil.
What the engine was designed to run on is probably irrelevant as it has probably
briane Offline
#3 Posted : Saturday, 6 January 2007 7:58:26 AM(UTC)
briane
Gidday guys. When you say run full 12v to the HEI coil, How do you do it?..Cheers
#4 Posted : Saturday, 6 January 2007 7:46:47 PM(UTC)
Either bypass the resistor wire in the harness on a Holden, or in the Landrover it might just simply require removal of a ballast resistor - normally looks like a ceramic box connected to the +ve terminal of the coil.
__________________________________
#5 Posted : Sunday, 7 January 2007 1:42:05 AM(UTC)
hi colin did you check your ignition timing & make sure the harrmonic balancer has not spun as they often do allso check the fuel mixture
