Hi guys. I have a tailshaft out of a HJ statesman with a T400. Will this go into a HZ van with a trimatic, or are the yokes/splines/lengths different? I assume the diffs are much the same or am I wrong there? Cheers
Hi hainzy.
The TH400 uses a different yoke with different splines when compared to a Tri-Matic and the tailshaft length is also different.
Dr Terry. |
I've got a spare one that should fit. Out of a HJ van with 3 speed and banjo diff.
Wrong rear uni unless it's a V8 banjo (I'm assuming Hainzy has a 10-bolt here?). You need one out of a V8 trimatic, 3 speed, 4speed or TH350 HQ-WB van, ute, wagon or statesman.
_______________________________________________________ If we all had the |
Where are you? I have a tailshaft out of a HX manual 3 on the tree 253 wagon if that helps.
Hi guys. Cheers for all the posts. Just to sort everything out. Firstly Im in ballarat. And yep I have the tailshaft metioned above, as well as a T400 out of a HJ stato. I also have an original HZ sandman which has no gearbox or tailshaft. I think I'll tr
