hainzy Offline
#1 Posted : Sunday, 18 February 2007 12:35:38 AM(UTC)
hainzy
Hi guys.
I have a tailshaft out of a HJ statesman with a T400. Will this go into a HZ van with a trimatic, or are the yokes/splines/lengths different? I assume the diffs are much the same or am I wrong there?
#2 Posted : Sunday, 18 February 2007 12:52:31 AM(UTC)
Hi hainzy.
The TH400 uses a different yoke with different splines when compared to a Tri-Matic and the tailshaft length is also different.
Dr Terry.
hainzy Offline
#3 Posted : Sunday, 18 February 2007 1:20:15 AM(UTC)
hainzy
Thanx Dr Terry.
Sandman Offline
#4 Posted : Sunday, 18 February 2007 3:03:17 AM(UTC)
Sandman
I've got a spare one that should fit. Out of a HJ van with 3 speed and banjo diff.
#5 Posted : Sunday, 18 February 2007 6:40:23 AM(UTC)
Wrong rear uni unless it's a V8 banjo (I'm assuming Hainzy has a 10-bolt here?). You need one out of a V8 trimatic, 3 speed, 4speed or TH350 HQ-WB van, ute, wagon or statesman.
If we all had the
Sandman Offline
#6 Posted : Sunday, 18 February 2007 9:29:11 PM(UTC)
Sandman
It was just a 6 cyl van.
#7 Posted : Monday, 19 February 2007 10:03:44 AM(UTC)
Where are you? I have a tailshaft out of a HX manual 3 on the tree 253 wagon if that helps.
hainzy Offline
#8 Posted : Monday, 19 February 2007 6:54:15 PM(UTC)
hainzy
Hi guys. Cheers for all the posts. Just to sort everything out. Firstly Im in ballarat. And yep I have the tailshaft metioned above, as well as a T400 out of a HJ stato. I also have an original HZ sandman which has no gearbox or tailshaft. I think I'll tr
