#1 Posted : Thursday, 5 July 2007 12:57:14 AM(UTC)
how do hydraulic lifters work ?
jabba Offline
#2 Posted : Thursday, 5 July 2007 4:55:58 PM(UTC)
jabba
Standard (solid) lifters are a cylinder with a dished cup in one end (that the pushrod sits in) with an oil hole in it, that connects to a hole in the side. Under normal operation, the oil comes in the side and out the top, through the hollow) pushrods a
#3 Posted : Friday, 6 July 2007 1:55:30 AM(UTC)
thanks for the info jabba so do you need fill them with oil first before putting them in ?cheers
jabba Offline
#4 Posted : Friday, 6 July 2007 6:32:56 AM(UTC)
jabba
No. They fill very quickly once the engine begins running. But it is a good idea to put either oil or assembly lube in the cup and on the following surface when puttingi them in.
If you are particularly worried about it, you can disable the spark and
#5 Posted : Saturday, 7 July 2007 2:07:14 AM(UTC)
thanks again jabba for all the info i love to learn cheers
charlie Offline
#6 Posted : Saturday, 7 July 2007 3:15:13 AM(UTC)
charlie
Hay jabba
Whilst on the topic whats the pros and cons on the standard v hydro???
jabba Offline
#7 Posted : Tuesday, 10 July 2007 11:08:12 PM(UTC)
jabba
Standard are easier to build and maintain, but you have to manually set the valve train lash. Hydraulic means no valve lash setting (well, some, but very forgiving), but need appropriate oil to work properly.
