VL05 Offline
#1 Posted : Thursday, 5 July 2007 5:12:32 AM(UTC)
VL05
G'day, looking at purchasing a 308 with engine number quoted from the seller as:
QI165821
I assume the I should be an L or a T but from the proceeding numbers is it possible to tell which one it should be?
WANTED: HJ Sandman parts, PM me!
WANTED: GTS rims, seats and mirrors to suit HJ.
#2 Posted : Thursday, 5 July 2007 5:28:40 AM(UTC)
a 308 would be QT if it is from an HQ to HZ, this one would be from an HQ.
QL would be a 202 engine.
Warren
VL05 Offline
#3 Posted : Thursday, 5 July 2007 8:06:44 AM(UTC)
VL05
Thanks mate.
#4 Posted : Wednesday, 11 July 2007 8:49:42 AM(UTC)
how can i find out what model engine i have, the first letters on my block are IIQT its in my vs if any one has any info please let me know
#5 Posted : Wednesday, 11 July 2007 4:13:34 PM(UTC)
HQ-HZ red 308, well the number is anyway. Check the side of the block to see if it has 308 on it. Also check the casting date on the front of the block just above the water pump. Number in the format: 11E5 that is number, letter, number. If it's an early
JBM Offline
#6 Posted : Wednesday, 11 July 2007 6:32:26 PM(UTC)
JBM
#7 Posted : Thursday, 12 July 2007 7:59:59 AM(UTC)
hey guys, i bought the vs with that engine in it,its an injected motor,dont know what has been done to it,if any one could tell me what sort of car it was from and year, and how i would go about finding what parts on it can you please let me know. block s
#8 Posted : Thursday, 12 July 2007 4:13:40 PM(UTC)
It will be 11QT. No such holden V8 as IIQT. If it is II then it's been restamped and may be stolen. 1971-1979 HQ-HZ Statesman. Tell me the whole number and i'll tell you what model and year. Even better if you post the casting date as well.
___________
coley13 Offline
#9 Posted : Thursday, 12 July 2007 8:07:54 PM(UTC)
coley13
could you guys tell me what engine i have, it's in a WB ute but i'm guessing it's earlier model
QR810434 also at top of the block near water pump it's says 14K6
Edited by user Thursday, 12 July 2007 8:13:18 PM(UTC)  | Reason: Not specified
#10 Posted : Thursday, 12 July 2007 8:30:09 PM(UTC)
coley 14/11/1976 hx 253
#11 Posted : Thursday, 12 July 2007 10:14:23 PM(UTC)
Almost correct - it's 14/10/76. There is no I used in the month coding.
coley13 Offline
#12 Posted : Friday, 13 July 2007 2:33:45 AM(UTC)
coley13
i was worried about that seeing it's in an 80 WB ute. it's going in for a blue slip soon and the mechanic said seeing i'm running straight gas it should be alright. i sure hope so. joys of buying cars on Ebay. thanks for the information cheers, Craig
#13 Posted : Friday, 13 July 2007 4:28:33 AM(UTC)
hey guys, does it make a diffrence if i have the hq statesman block and it being injected? what would they have done to get it running with the injected gear, i know that i VS111 computer is running it, any info on how or what was maybe done to get it goi
#14 Posted : Friday, 13 July 2007 6:33:42 AM(UTC)
That's a HX block. Barring the different drillings for 4speed vs TH autos the blocks are basically the same between the early 1969 HT Brougham block right through to a late 2000 VSIII. The only insurmountable difference is once VT was released the blocks
#15 Posted : Saturday, 14 July 2007 1:54:02 AM(UTC)
thanks byron. is it true that there were some A9X torana motors 'only for motorsports'with HP on both sides of the block. and bigger HP then normal.
#16 Posted : Saturday, 14 July 2007 4:19:35 AM(UTC)
No. The ones with HP are just ordinary 308's, in fact the first of them. Most of them were in HT Broughams as the 308 was only available in Brougham until 307's ran out. For a few months post the end of 307 the rest of the HT range got the 308 with HP and
#17 Posted : Saturday, 14 July 2007 10:25:47 AM(UTC)
Hey Byron rich,
do the hq statesman block have the same piston and the rest of the running gear in the block the same as the newer blocks, or are they completely diffrent? what info can you tell me about that block, cheers mate
boom Offline
#18 Posted : Sunday, 15 July 2007 1:03:46 AM(UTC)
boom
block are essentially the same, but internals are completely different (i.e 308 -> 304)
If it doesn’t burn fossil fuels, it’s not a sport.
#19 Posted : Sunday, 15 July 2007 8:22:40 PM(UTC)
#20 Posted : Sunday, 15 July 2007 10:49:30 PM(UTC)
Sounds like an F5000 block, but normal HP blocks aren't F5000 blocks. They are identical to all other HT-HQ blocks. And they certainly weren't cast in 1978. I also wasn't aware of F5000/L34 blocks being 4 bolt. They were higher nickel content and I think
Guest (5)
