FAT400 Offline
#1 Posted : Wednesday, 18 July 2007 10:52:39 PM(UTC)
FAT400
My brother inlaw want to put a sbc in his hj sedan. Can anybody help with numbers on id tags that would tell him wether he is allowed or not allowed any help much appreaciated thanks paul
#2 Posted : Thursday, 19 July 2007 4:00:48 AM(UTC)
No HJ came out with a chev motor , the HQ was the last of the oldies with a 350. You would have to check with the RTA in your state, it will fit no probs but check what is required to make it legal.
FAT400 Offline
#3 Posted : Thursday, 19 July 2007 9:11:23 PM(UTC)
FAT400
thanks cloudy i have a HQ with a 400 cube in it . and the brother would like to thro a 350 in his hj il have to find the rta tech line phone number. thanks heaps
jabba Offline
#4 Posted : Thursday, 19 July 2007 9:21:17 PM(UTC)
jabba
Fits nice enough though. HJ monaro with 350, only required new engine monts and crossmember.
FAT400 Offline
#5 Posted : Thursday, 19 July 2007 9:42:48 PM(UTC)
FAT400
so jabba not meaning to sound like a nob here. do you mean that hj came out with a 350 or only the coupe not a sedan
#6 Posted : Thursday, 19 July 2007 10:07:26 PM(UTC)
350 stopped in HQ. It's easy to get a 350 Engineered for a HJ though. All you need is to hook up the canister to the carby correctly, and have a PCV valve. I think that's about it. The rest of the stuff the Engineer has to worry about is simple as all he
jabba Offline
#7 Posted : Thursday, 19 July 2007 10:32:19 PM(UTC)
jabba
The HJ GTS I have was originally a 308, turbo 400. Replacing the 308 with the 350 (1st time) required only engine mounts (according to the cert papers). The second replacement involved a gearbox crossmember replacement as well (I know not why, given tha
74HJLS Offline
#8 Posted : Friday, 20 July 2007 7:09:25 PM(UTC)
74HJLS
Byron, not all HJs came with the canister, but as you say there is only cosmetic differences and HQ gear will do it. In QLD to put a different motor in without engineers tags you are allowed a 10% HP increase on the largest motor available for that model
Edited by user Friday, 20 July 2007 7:16:05 PM(UTC)  | Reason: Not specified
Pete.
FAT400 Offline
#9 Posted : Saturday, 21 July 2007 7:16:27 PM(UTC)
FAT400
CAR IS IN TOTALLY 100 % ORIG CONDITION IT HAS NO CHARCOAL CANISTER AT ALL AND NO PIPES OR LINES NOT BEING USED. AND HAS NO EMISSION NUMBERS ON ID TAGS WITCH I SPOZE IS IN HIS FAVOUR . IF HE IS GOING TO HAVE TO MANY HASSLES PUTTING IN A CHEV HE WILL DO
Edited by user Saturday, 21 July 2007 7:21:46 PM(UTC)  | Reason: Not specified
#10 Posted : Sunday, 22 July 2007 1:23:35 AM(UTC)
Hi FAT400
You have an HJ sedan that doesn't have ADR27 on the ADR compliance plate !!
I understand that if this car is a 1974 HJ then it won't have had a canister & lines, but AFAIK ALL Australian delivered HJ passenger cars had ADR27 on the plate.
