You are a member of these groups:: Registered
My brother inlaw want to put a sbc in his hj sedan. Can anybody help with numbers on id tags that would tell him wether he is allowed or not allowed any help much appreaciated thanks paul
No HJ came out with a chev motor , the HQ was the last of the oldies with a 350. You would have to check with the RTA in your state, it will fit no probs but check what is required to make it legal.
thanks cloudy i have a HQ with a 400 cube in it . and the brother would like to thro a 350 in his hj il have to find the rta tech line phone number. thanks heaps
Fits nice enough though. HJ monaro with 350, only required new engine monts and crossmember.
__________________________________________ Keep the shiny side up, and the greasy side down. |
so jabba not meaning to sound like a nob here. do you mean that hj came out with a 350 or only the coupe not a sedan
Thanks: 1 times Was thanked: 605 time(s) in 572 post(s)
350 stopped in HQ. It's easy to get a 350 Engineered for a HJ though. All you need is to hook up the canister to the carby correctly, and have a PCV valve. I think that's about it. The rest of the stuff the Engineer has to worry about is simple as all he |
The HJ GTS I have was originally a 308, turbo 400. Replacing the 308 with the 350 (1st time) required only engine mounts (according to the cert papers). The second replacement involved a gearbox crossmember replacement as well (I know not why, given tha |
Byron, not all HJs came with the canister, but as you say there is only cosmetic differences and HQ gear will do it. In QLD to put a different motor in without engineers tags you are allowed a 10% HP increase on the largest motor available for that model Edited by user Friday, 20 July 2007 7:16:05 PM(UTC)
| Reason: Not specified |
Cheers, Pete. Old Holdens never die, they just go faster. |
CAR IS IN TOTALLY 100 % ORIG CONDITION IT HAS NO CHARCOAL CANISTER AT ALL AND NO PIPES OR LINES NOT BEING USED. AND HAS NO EMISSION NUMBERS ON ID TAGS WITCH I SPOZE IS IN HIS FAVOUR . IF HE IS GOING TO HAVE TO MANY HASSLES PUTTING IN A CHEV HE WILL DO Edited by user Saturday, 21 July 2007 7:21:46 PM(UTC)
Thanks: 1 times Was thanked: 243 time(s) in 217 post(s)
Hi FAT400
You have an HJ sedan that doesn't have ADR27 on the ADR compliance plate !!
I understand that if this car is a 1974 HJ then it won't have had a canister & lines, but AFAIK ALL Australian delivered HJ passenger cars had ADR27 on the plate. |
