Hi all,
I have a LX SLR with a 6 cylinder. Prior to replacing it to a V8, how can i check to see if this engine was originally came with the car as it was produced?
I have spoken to Vicroads, but seem to be going in circles.
Jamie
the guys on the forum might need the plate no: the engine model trans and axle no: all on the fire wall. DR TERRY or BYRON RICH are the dudes too talk to when it comes to numbers,they might help .
its beer oclock |
On The Other Hand There's Finger's |
it's beer o'clock |
If you have a genuine SL/R the only 6 cylinder engine available was the 3.3 (202), the VIN will start with 8D69L... and the engine code on the Body ID plate will be L20 with an M20 or M40 Trans. The Model No for an SL/R is 8VD69. The original 202 engin Edited by user Sunday, 5 August 2007 8:44:04 AM(UTC)
| Reason: Not specified |
You only have to be in front at the end of the race. |
Guys,
Thanks for the prompt replies!
The Engine Number is HL66***
ID Plates: Model Number LX8VD69 Body Number 550477M Trim Number 1896-18V Paint 567-15942 Engine L20 Trans M20 RRAXLE GV4
Middle Tag: 8D69LCJ550477A
On the face of it,
I actually saw a 173 powered LX SL/R once. The VIN plate had a D and it had the 173 code on the BODY plate. Never saw another one.
_______________________________________________________ If we all had the same (good) taste, who would buy all the For |
The colour is Contessa Gold Metallic, the trim is Slate Black Vinyl with vinyl insert.
M20 is a wide ratio Aussie 4 speed.
The body is Dandenong built and assembled.
The last character of your VIN (Middle Tag) should be an X.
Just as a check y |
James,
Thanks for the responses!!!
I will be starting the rebuilding/restoring process over the coming weeks!
Jamie
