Holden One Offline
#1 Posted : Sunday, 5 August 2007 6:33:15 AM(UTC)
Holden One
Hi all,
I have a LX SLR with a 6 cylinder. Prior to replacing it to a V8, how can i check to see if this engine was originally came with the car as it was produced?
I have spoken to Vicroads, but seem to be going in circles.
Jamie
hz dude Offline
#2 Posted : Sunday, 5 August 2007 7:28:23 AM(UTC)
hz dude
the guys on the forum might need the plate no:
the engine model trans and axle no:
all on the fire wall. DR TERRY or BYRON RICH
are the dudes too talk to when it comes to
numbers,they might help .
its beer oclock
hz dude Offline
#3 Posted : Sunday, 5 August 2007 7:28:23 AM(UTC)
hz dude
it's beer o'clock
JBM Offline
#4 Posted : Sunday, 5 August 2007 8:40:10 AM(UTC)
JBM
If you have a genuine SL/R the only 6 cylinder engine available was the 3.3 (202), the VIN will start with 8D69L... and the engine code on the Body ID plate will be L20 with an M20 or M40 Trans. The Model No for an SL/R is 8VD69.
The original 202 engin
Edited by user Sunday, 5 August 2007 8:44:04 AM(UTC)  | Reason: Not specified
Holden One Offline
#5 Posted : Sunday, 5 August 2007 7:09:34 PM(UTC)
Holden One
Guys,
Thanks for the prompt replies!
The Engine Number is HL66***
ID Plates:
Model Number LX8VD69
Body Number 550477M
Trim Number 1896-18V
Paint 567-15942
Engine L20
Trans M20
RRAXLE GV4
Middle Tag:
8D69LCJ550477A
On the face of it,
#6 Posted : Sunday, 5 August 2007 7:33:40 PM(UTC)
I actually saw a 173 powered LX SL/R once. The VIN plate had a D and it had the 173 code on the BODY plate. Never saw another one.
If we all had the same (good) taste, who would buy all the For
JBM Offline
#7 Posted : Monday, 6 August 2007 6:00:01 AM(UTC)
JBM
The colour is Contessa Gold Metallic, the trim is Slate Black Vinyl with vinyl insert.
M20 is a wide ratio Aussie 4 speed.
The body is Dandenong built and assembled.
The last character of your VIN (Middle Tag) should be an X.
Just as a check y
Holden One Offline
#8 Posted : Monday, 6 August 2007 6:06:24 AM(UTC)
Holden One
James,
Thanks for the responses!!!
I will be starting the rebuilding/restoring process over the coming weeks!
Jamie
