Hi Guys Am currently in the process of replacing my 327 chev with a 308, and was planning on using the same gearbox(th400), tailshaft and diff.. Was hoping to just replace engine. I have noticed that the 308 is a couple of inches shorter than the chev, so my question is, does this bring the gearbox forward as well and will I have to get another crossmember and tailshaft to suit, or does it still all match up.
Cheers Shane
If the TH400 is in the original spot for a HQ-HZ it will all fit.
Thanks Byron I assume that it is in the original spot as crossmember is bolted to the original holes on the chassis
Cheers Shane
What is the 327 out of?
Byron I got 327 out of a HJ prem, But have been told after I sold it that it was originally from a series 1 Hk monaro. Guy was spewing as he wanted for his. Cheers Shane
