farrblake Offline
#1 Posted : Friday, 10 August 2007 3:02:48 AM(UTC)
farrblake
Hi Guys
Am currently in the process of replacing my 327 chev with a 308, and was planning on using the same gearbox(th400), tailshaft and diff.. Was hoping to just replace engine. I have noticed that the 308 is a couple of inches shorter than the chev, so my question is, does this bring the gearbox forward as well and will I have to get another crossmember and tailshaft to suit, or does it still all match up.
Cheers Shane
#2 Posted : Friday, 10 August 2007 4:37:53 AM(UTC)
If the TH400 is in the original spot for a HQ-HZ it will all fit.
farrblake Offline
#3 Posted : Friday, 10 August 2007 4:43:51 AM(UTC)
farrblake
Thanks Byron
I assume that it is in the original spot as crossmember is bolted to the original holes on the chassis
Cheers Shane
#4 Posted : Friday, 10 August 2007 7:17:06 AM(UTC)
What is the 327 out of?
farrblake Offline
#5 Posted : Saturday, 11 August 2007 4:11:12 AM(UTC)
farrblake
Byron
I got 327 out of a HJ prem, But have been told after I sold it that it was originally from a series 1 Hk monaro. Guy was spewing as he wanted for his.
Cheers Shane
This page was generated in 0.022 seconds.
