JBM Offline
#1 Posted : Friday, 17 August 2007 7:05:56 AM(UTC)
JBM
Is there another method for separating the lower ball joint from the spindle without the proper tool or a ball joint fork?
Have tried hitting the threaded shaft while putting pressure between the control arm and the spindle.
I want to change the strut insert and spring.
Have been quoted $100 in labour to change both sides should I just get someone else to do it?
James
arse_wipe Offline
#2 Posted : Friday, 17 August 2007 7:37:48 AM(UTC)
arse_wipe
Do not hit the thread,,
You need to hit the strut where the ball joint shaft seats,,
You must get a good swing at it and hit with enough force to shock loose the taper on the shaft of the joint,,(do not use a small hammer)
If you hit the thread you wil
John
Silence is non-committal
adam PERTH Offline
#3 Posted : Friday, 17 August 2007 7:38:55 AM(UTC)
adam PERTH
ball joint fork = $20.
try that first.???
always have to have the right tool for the job. cheers,
Being a Bogan is finally paying dividends.
JBM Offline
#4 Posted : Friday, 17 August 2007 6:19:56 PM(UTC)
JBM
Nothings open here at 8pm and the cars partly disassembled, Ill have to get the bus to town. BTW I was using a copper hammer to avoid damaging the thread. Forgot about hitting it on the side, its been a while since Ive down any suspension stuff. Thanks.
JBM Offline
#5 Posted : Friday, 17 August 2007 6:19:56 PM(UTC)
JBM
Nothings open here at 8pm and the cars partly disassembled, I'll have to get the bus to town. BTW I was using a copper hammer to avoid damaging the thread. Forgot about hitting it on the side, its been a while since Ive down any suspension stuff. Thanks.
#6 Posted : Friday, 17 August 2007 6:20:28 PM(UTC)
Hi Guys.
John (Mr wipe) has got it one. I've removed 1000s of ball joints & tie rod ends etc & have never used a fork tool. I always smack the tapered hole on the side. In other words when removing tie rod ends, hit the end of the steering arm, when do
#7 Posted : Friday, 17 August 2007 6:20:28 PM(UTC)
Hi Guys.
John (Mr wipe) has got it one. Ive removed 1000s of ball joints & tie rod ends etc & have never used a fork tool. I always smack the tapered hole on the side. In other words when removing tie rod ends, hit the end of the steering arm, when doi
JBM Offline
#8 Posted : Saturday, 25 August 2007 7:14:03 PM(UTC)
JBM
Hitting the strut base worked and the ball joint popped out, both sides!
Thanks for the tips, just putting it back together now.
James
