Is there another method for separating the lower ball joint from the spindle without the proper tool or a ball joint fork?
Have tried hitting the threaded shaft while putting pressure between the control arm and the spindle.
I want to change the strut insert and spring.
Have been quoted $100 in labour to change both sides should I just get someone else to do it?
James
You only have to be in front at the end of the race. |
Do not hit the thread,, You need to hit the strut where the ball joint shaft seats,, You must get a good swing at it and hit with enough force to shock loose the taper on the shaft of the joint,,(do not use a small hammer) If you hit the thread you wil |
Cheers John Silence is non-committal |
ball joint fork = $20. try that first.???
always have to have the right tool for the job. cheers,
Being a Bogan is finally paying dividends. |
Nothings open here at 8pm and the cars partly disassembled, Ill have to get the bus to town. BTW I was using a copper hammer to avoid damaging the thread. Forgot about hitting it on the side, its been a while since Ive down any suspension stuff. Thanks.
Nothings open here at 8pm and the cars partly disassembled, I'll have to get the bus to town. BTW I was using a copper hammer to avoid damaging the thread. Forgot about hitting it on the side, its been a while since Ive down any suspension stuff. Thanks.
Hi Guys.
John (Mr wipe) has got it one. I've removed 1000s of ball joints & tie rod ends etc & have never used a fork tool. I always smack the tapered hole on the side. In other words when removing tie rod ends, hit the end of the steering arm, when do |
Hi Guys.
John (Mr wipe) has got it one. Ive removed 1000s of ball joints & tie rod ends etc & have never used a fork tool. I always smack the tapered hole on the side. In other words when removing tie rod ends, hit the end of the steering arm, when doi |
Hitting the strut base worked and the ball joint popped out, both sides!
Thanks for the tips, just putting it back together now.
James
